Back then you couldn't code much of anything with hard wire open arc mig (had a bad name for good reason).
Just used the Ar-5Co2 because it
could short circuit & it pulsed pretty well (handy if you need to replace a sharp corner on something). Volt settings for short circuit are going to be LESS than what you'd use for straight up steel mig.
A DAB's right about trying to short circuit with Ar-2o2 or Co2 - not cool, that mix is for 'medieval type' spray using a #14 shade, leathers & putting some vasoline on the neck for burn protection. The stainless is worse than aluminum for smoking your tender self.
I get a kick out of Ed Craig, he's a shameless self promoter that loves the game (no sin I guess). Per the linked article he's pretty much right about the gas man sucking the money out of your account & into his. Better to look to europe for steady gas numbers - they don't seem to be dazzled by hype.
For instance (just checked some old rags)- The fabricating & welding handbooks that used to be published every 2 years for the AWS conventions had pretty much the latest trends & newest AWS spec changes & weld bling. In '84-5 the only short arc stainless mix listed in the gas section was the He tri-mix, and Ar-5o2 for spray,
but there were no parameters listed for any hard wire mig in the stainless welding section. By '88-89 the stainless section shows He tri-mix for short arc & Ar-5o2 for spray with range parameters. In '90-91 shows the tri-mix & C25 for short arc and adds 1&2 o2 plus the 1&2 Co2 for spray
with rifle shot parameters (full tables for each transfer type vs mix)... The Ar-5o2 had been dumped for spray BTW... There's a lot of bla-bla-bla that goes on out there & you're stuck sorting it out the hard way.
I remember the tin knocker "UA" shop down the street & their preference for electrode on heavy gage work rather than hard wire mig. They didn't get happy with mig-ing stainless until the cored wires got figured out & then they loved it. I'm pretty sure it was ease of use & appearance because their stick welds looked really nice - always.
Matt
