21 - 38 of 38 Posts
That stuff looks perfect. Think the 3 superflex water cooled hoses will fit in this 1" stuff?
http://www.ebay.com/itm/Tubular-Web...id=f7d0b5fa7e414ad18b64a6752309233e&pid=100005&rk=5&rkt=6&sd=271900195870&rt=nc
I guess it would all depend on the actual opening area available due to the stitched ends. The CK superflex-trio fit inside a 5/8" square/circle.
If that 1" designation is correct, I see no reason why it would not fit :confused: then again, that sure looks more like 2" wide, lol.
Dang!!!!!!!!!!!
It is called the Cowboy cover. For $14 bucks for a 25 foot zippered cover and free shipping you can't go wrong. Sure it is from China, but a unique and very light solution that I have never seen before. Too bad they can't use black denim.
Good find!
Tough, lightweight, and inexpensive. 2" tubular webbing for rock climbing.
How could I have overlooked this simple fix. Been using this stuff for everything from protecting the drink-tube on the CamelBak to making a slack-line. Great reminder brother!
Gar
Gar
Agree w/ all that's been said re: how tough and flexible nylon climber's webbing is. It's also not very heat resistant; hot BB's will sink through it like the Alien's blood went through the ship's floor in the Sigourney Weaver movie. Generally not a big issue w/ tig.
@ Weld - :cool:
@ MikeGyver - measured a remnant of the Red tubing in the shop. 2" flat (external) yields a maximum usable ID of 1-1/8". She'll work fine for your 3-piece CKW water torch setup. When you go to cut the webbing to length, wrap electrical tape around each bitter end, razor cut midspan across the tape and thru the webbing, remove tape, zippo burn each end to seal threads. For burn-in, ensure you do not close up the circle, just nip each end.
The Blue webbing in the shop is 1" flat (external) with a usable internal ID of ~ 1/2". Blue's good for a one-piece SuperFlex.
During FABTECH'15, was gifted this FlexTech sample kit from a pretty young wahine. The kit consists of 1" turtle wrap, 3/4" FT, 3/4" insultherm, 7/8" flex, 3/4" flexo, 1/2" gorilla, and 1-1/2" thermashield. The 1" turtle wrap, shown 2nd from right in image below has velcro, while the remaining samples are seamless.
Installed the 1" dia x 3" long turtle wrap sample on water-cooled CKW flex hose TIG torch to 'close the gap'. The TIG torch is currently setup with a POS zipper cover that's disastrous. The turtle fits nicely. Planning to order a 25' TW ($95) and install on our water-cooled CKW FlexLoc TIG setup. :cool:
OEM specs on the turtle from the TechFlex site,
"Turtle Wrap is made of 1,000 Denier Cordura, and double coated with proprietary high FR Neoprene. This protection sleeve is used for bundling and wrapping hoses and cables. The reusable sleeve features Mil-Spec extreme Hook & Loop closure which allows installation without disconnecting hoses and can reduce labor time by 70%. TW is an excellent choice for weld cable or welding hose that is often dragged across the floor. This material resists sparks and hot spall. Turtle Wrap is also used in Subsea maintenance where barnacles, sea life and salt water can damage hoses. This sleeve is also heavily used on off-shore oil rigs. Turtle Wrap is available in Black."
Did you give up on the tubular webbing?
@ Weld - neg, still retaining the red tubular webbing on a CK17 dual-hose air cooled torch & blue tubular webbing on a CK17 single-hose, valved, torch. The webbing has performed flawlessly.
The 'Honu' (Turtle Wrap) will be integrated to our CKW FlexLoc tri-hose torch. The velcro, lightweight, and abrasive features of the Honu are attractive. Echoes to days of future past when we used velcro covers on our deep sea umbilicals for SSDS ops. :cool:
tubular webbing is some of my favorite.
Recently installed 25' of 1" TurtleWrap from FlexTech onto a water-cooled 18-Series CKW TIG Torch w/ SuperFlex hoses. Simple to install/deinstall,pliable, super-light, and melts at 800F. Done with any zipper covers. Done. The old Radnor one that came with our first TIG torch was disastrous. Failed/snapped zipper, suck teeth, and no lighter than the "HonuWrap". That POS is now in the trash.
Looks like "Turtlewrap" is basically "Tough Duck".
I used the leather velcro wraps, but if your cooling line decides to crap out on you, they turn to a slimy sticky grossness. Kind of like a freshly chewed rawhide.:blush2:
The only thing I do'nt like about webbing is the amount of crap swept off the floors and sticks to them.
Not quite. TurtleWrap is made from 1000 Denier CORDURA, a Nylon 66 based product that first gained commercial popularity in the late 60s, and a fire-resistant Neoprene coating. Tough Duck, if you mean the trade name, is a 600 Denier canvas product made with polyester.
CORDURA is mildew resistant, whereas Duck is more prone to retaining mildew. Have no insight into the fire resistantanve of Tough Duck but it ain't holding up to temps of 800F unless there's some magic fairy dust applied to the surface.
Note, the Denier value has nothing do with strength as many assume, but rather a measure of specific weight (weight per unit area).
Cordura has a "Tough Duck". My ex-gf's family sells it by in bulk in their store and manufactures products from it. It has a weave texture on the front, and smooth plastic on the back. It definitely is not canvas by any means, and it is thick.
Late to the party, but wanted to say that this tubular webbing is a great solution. I just set up a 25 foot CK 26 with BlueWater 2" Climb-Spec Webbing. The torch cable fit easily through the webbing. The webbing is thick and seems durable. The webbing offers no resistance to bending and I think this will work out well for this (large to me ) torch. At 70 cents a foot, it's sure worth a try. Thanks ManoKai for the idea.
I do like the idea of tubular webbing, the friction drag will be almost zero.
I hate rubber or leather covers just for the drag you get, although suede is much much nicer. I went with a cheap as chips chinese denim cover for my last torch, I really like it :)
21 - 38 of 38 Posts
