Welding Chainmail
1 reading
12K views 26 replies 11 participants last post by  rick-l
I'd like to weld the links of my mail, but I decided to stop using my resistance welder because I was having issues that made welding uncomfortable. The main issue being sometimes the electrodes would throw sparks or blow a chunk out of the ring even though I tried to do everything as carefully and consistently as possible. I'm sure it was somehow user error, but regardless I'd like to find a more comfortable alternative instead of bracing myself for a small explosion before welding each ring. (I welded about 400 rings before things starting getting consistently hairy, so I'm not sure exactly what was suddenly causing problems.)
Welding mail requires thousands of precision welds, so I'd like to find something that will be consistent, simple, and provide strong but relatively pretty welds.
The links I use are 1.6mm and 2mm.
I know next to nothing about what's available in the world of welding, so any and all advice and suggestions are welcome! I would MUCH rather weld than rivet!
#2 ·
Oh Toasted One,
By way of an experiment you could make up a couple of these rings put them in an envelope and mail them to me and I'll see what I can do as far as fusing them together with a TIG welder to see if that might be a viable option. I'm not saying for sure it will work but if you're willing to risk a couple of rings being destroyed it won't take me but around 5 minutes to figure out if it's doable or not. Plus then if it does work I can send them back and you can check the weld quality by doing some destructive testing on them.
#4 ·
Good to know!
HT2 - That would be great! I don't mind sending you some rings. Strength testing them is pretty simple. The wire I'm using is soft, so a good way to test is to simply bend the ring to see if the weld breaks. If the ring bends instead of the weld snapping apart, it's definitely strong enough for what I'll be using it for. Just PM me your address, and I'll send them your way tomorrow.
#6 ·
So 15,000 links would make a piece of chainmail covering bow big by how big? :) And what would that weigh?
#8 ·
Did some looking into chain mail welding and learned some stuff.
Looks like there's two main ways they go at it. Either resistance or pulsed arc (which is a specialized form of TIG).
http://theringlord.com/cart/shopdisplayproducts.asp?id=164&cat=Welders
This manual on the "resistance welding of butted rings" was enlightening.
http://theringlord.com/Instructions/ResistanceWeldingofButtedRings.pdf
This manual on the pulsed arc welder helps explain how it works.
http://theringlord.com/instructions/JewelryWelderManual.pdf
#13 ·
Toasted One,
After looking around the Interweb some more for information on this subject I'm coming to the conclusion that resistance welding is probably going to be your best option for what you're trying to do. My original thought of using a manual tig torch to fuse tack each link would be really slow and cumbersome. It looks to me like you need to have both hands free to manipulate and weave the rings together as you go.
If you'll post some pictures of your resistance welder and how your work station is set up I could probably give you some ideas on how to make it more user friendly.
#22 ·
your answer is probably here, somewhere- " (I welded about 400 rings before things starting getting consistently hairy, so I'm not sure exactly what was suddenly causing problems.)".
So it worked, then it didn't. Have you contacted the welder supplier for their input?
Is the material the same batch?
Was there surface contamination to cause a resistance between the electrode and ring?
one thing that struck me as odd about that set up was the electrode ends ought to have a small groove to keep the ring from sliding when pushed into the electrode. And that a timer would give a lot better control than a switch.
#25 ·
I figured it out.
You have to scroll through the whole sequence menu and then I think you have to press the A button twice to set the weld time.
Step on the pedal and it delivers a burst. pretty cool
Does this sound stupid and risk injury? put alligator clips on the two wires connected to ground, push the wires together, hold them up near the torch and step on the pedal. I think I need a little pressure to get good fusion.
#26 ·
Not stupid. You using the spot timer. I do it when tacking parts with a high burst of current.
#27 ·
Not the original poster just curious.
I was playing with this 1/16th inch wire just to see how it worked. I forgot your recommended settings and somehow arrived at 30 Amps 1/2 second (little too hot?). I slightly squeezed them with a pliers which the ground clamp was attached to.
At about 30 seconds each it will take you 125 hours to weld 15,000 of them.
