Is it possible to weld aluminum with an AC-225 stick. I have done some research and I have found that some say you can and some say you cant. If its possible what electrode should be used? Any help would be appreciated.
A couple of years ago a guy gave me 3 Al welding rods. Ran them. I have pictures but my attachment button won't work.
The beads were not pretty, though no problem with burn through or adhesion. They are a mess to clean up after. The flux is like that of brazing. I don't know how good they can get since I only had three rods.
Ran it reverse polarity. Too much current and spatter the size of pea size hail flies and hits you in the top of the head.
I ask my vendor to let me try them and he gave them to me.
I've used the Lincoln Aluminum stick rod, and it sure does make a mess. I think you can only run it DCRP, and it burns REAL fast. You'll get about 3"-4" per rod. It's inexpensive, so that's a plus. Not the prettiest, but if you're outside and in a jam, it'll work. Other companies also carry it, and it welds nicer, but it's pricey. I think you are out of luck on AC though.----john
Only good for horzontal beads, out of position is a no-no. I wouldn't expect much with an a/c welder, AL should be welded d/c reverse polarity. I've done it and had no problems. Good luck!
I once repaired an aluminum chainsaw handlebar with a stick welder, also an aluminum cattle trailer, works pretty good, but you have to use DCEN it can lay a pretty nice bead. Just keep the amps down and make sure your metal is CLEAN. as for taking the flux off, yea that sucks a little acid and a wire brush does the trick
Related Threads
WeldingWeb - Welding Community for pros and enthusiasts
posts
1.8M
members
82K
Since
2003
Community Forum for Welding Professionals and Enthusiasts To Interact and Learn - Free
