Hi guys, just wondering if anybody has ever welded a piece of flat bar across the teeth of an excavator bucket to make a smooth edge. I work for an electrical coop that deals with underground utility lines. The excavator we have has a 24" bucket which works great but they are asking me if I can buy or build an attachment that will keep the bucket teeth from snagging on water lines buried in the same ditch as our cable. They are as careful as they can be and will dig by hand when they need to but accidents happen. My plan is too get a piece of 5/8" x 6" bar stock and weld it to the two center teeth and just have it lay against the two outside teeth for support. This way it's easier to remove and put two teeth back on if they need to. The problem I think I'm going to run into is welding the bar stock to the teeth, I was told that they teeth are hardened and I have not welded mild steel to hardened steel before. The teeth I'm working with are TF23D Fanggs on a John Deere bucket. I would appreciate any input.
Thanks
Thanks
