My 151 Dual MIG uses standard threaded tips. In fact at the moment I'm not using HF tips. I can't remember whose brand I'm actually using but they're not Tweco.
"Tweco style" is a very loose expression. HF torches aren't built by Tweco, they are built by whatever supplier they buy the welder from. I am certain it would not be difficult to adapt a Tweco brand torch to your welder, but to be honest, why would you want to? The torch will cost more than the welder, and you'd be better off investing your hard earned cash in a Lincoln, Miller or Hobart. That's not a put-down of the Chicago Electric welder. Most of their wirefeed process welders are decent if not pretty good. Certainly the best value out there.
If you break a torch per year on the HF welder that's 20 bucks a torch, which includes the new liner and wiring. My only complaint about mine is that the trigger can sometimes be a little touchy. But I've been using the same torch since I got it 6 months ago, and I've used it pretty hard. Even parked the welder on top of it once by accident without bending it.
If you have any doubt though (after all, you have a MIG 100 and I have the 151), remove the tip from your welder and cart it down to your local Ace or Depot or Lowes or wherever it is you have going on locally and see if you can find something that looks right.
