Hi
Back with a couple questions, like you already knew I'd
be back with more questions.
Lets see if I can make this make sense , so I'm reading alot with volts verses wire feed and the perfect combination. When your learning to weld you want good penetration between the two pieces of material, so to get this you push or pull the puddle ,if the weld bead is coming out tall do you increase the voltage/heat, speed up the push or pull of the weld or turn down the wire speed? I would imagine you don't decrease the voltage.
