Stainless Steel MIG Mix 98/2 Ar/CO2
20K views 36 replies 11 participants last post by  Weld_
I was wondering how many people in the community that weld stainless steel in large quantities utilizing the GMAW (mig) process utilize the 98/2 Ar/CO2 mix and what are your thoughts on it.
Any and all contributions are appreciated.
#2 ·
My LWS recommends 98%AR, 2%O. That is the mix used by a large metals fab shop near here. Had a bottle filled to attempt spray xfer but haven't had the time to try it yet.
Jerry
#4 ·
We were given that by our old LWS and it didn't run so nice compared to tri-mix. Kind of left a burned appearance.
At the time I was not doing the welding so it may have been operator error that went away when we swithed.
Mainly keep it for steel spray transfer.
Sent from my SM-G920P using Tapatalk
#6 ·
Thank you for sharing. Was that done in spray transfer? What was your gas flow if you remember, it seems like you might have been having a gas coverage problem. Also if you don't mind mentioning your wire feed speed and voltage.
#7 · (Edited)
Think he was "attempting" spray. Gas usually stays at 30cfh
He got reamed for that one[emoji36]
Now I will say to be fair that LWS had a habit of sending bad mixes and it took 2 months to get a tri-mix bottle and when it arrived, looked like it was buried in a field.
#9 ·
If those pieces got wasted that's definitely an expensive exercise, those are not cheap. I still think some sort of gas problem was the issue if they gave you a higher content CO2 that could have been your issue. Your LWS would not by any chance be Airgas, they are absolutely horrible at times.
#8 ·
used 98ar 2oxy for a couple years a few years ago when we were doing a lot of heavy stainless.
i could never get it to short cuircuit (sprays nice though)
always had a grey weld bead. but was easy to brush to shiny
only way to mig structural ss in my opinion. sheetmetal stuff gets tri-mix, anything above say 3/16 that could be wire fed was sprayed 98/2
#11 ·
We have a bottle of it at work, use it for welding nuts on 16ga 304... does as good of a job as the tri mix but costs a lot less what with the no helium involved thing.
These are 2 little tack welds onto a carbon steel coupling nut so its kinda hard to gauge, the few times I ran it setting the machine up it seemed to play pretty well on 16ga in various forms.
Seemed like if I had it in a better machine (with full volts/amps vs a tap voltage setup) that it could be made to run as nice as the helium blend.
#15 ·
It's okay I sometimes overlook things as well. I would recommend reading from the link above. Some real interesting information on the gases. To sum it up basically a lot of different metals can be welded optimally just utilizing argon and CO2 and varying the mix rates. This presents a lot of interesting opportunities by only having two large tanks and a gas mixer.
It also goes on to explain why argon CO2 combinations are superior to tri mix as well as argon oxygen mixes when dealing with gauge thickness.
#14 ·
For a quick splat or 2 yea... not really enough to give any kind of good report on it though. It behaved like if you ran pure argon with steel wire... but it sucked Slightly less. I wouldnt want to do it every day because 75/25 is a lot smoother but it might work if you want to have 1 gas for your mig to bounce between short circuit and spray on CS and SS.
#16 ·
It wasn't joining, but years back I had the displeasure of doing stainless overlays (automated) using hard wire from time to time. More to the point - programming the parameters used, someone else did the running bit. To me it was always a bit like pushing "paper" through a machine - troublesome.
Open arc spray or pulse - usually Ar/1-2%O2 (no carbon pick-up - sluggish - very shiny), sometimes Ar/5Co2 (also short arcs OK - welded the best of the 2 parts - more carbon pickup - grey bead, brush to shiny easily), Ar/2-3Co2/1-2Hydrogen (this also short arcs really good - best bead shape with solid wire - little to no carbon pickup - gold appearance - brush to shiny). Be careful with the hydrogen blend & test a short area first - it will cover gas holes created by the reducing flux atmosphere, you will never see it till you grind it or machine it, the puddle looks agitated but OK - learned that the hard way.
Sub arc - neutral flux - always shiny but you had to go over the whole surface & either stick or tig fill the areas where the bead wobbled before machining. That latter part was frustrating as solid stainless seems to for no reason "move over" like a 7018 puddle does around an inclusion of piece of junk in the surface.
For whatever reason it seems that a lot of suppliers are going back & pushing 90He/7.5Ar/2.5Co2 (old school mix for thin sheet & needs lots of volts)??? I saw the neighbor shop got a bottle a while back & just shook my head.
Matt
#17 ·
I really appreciate you sharing your knowledge and experience. I was wondering if you can elaborate on some of your argon CO2 mix experience. I know that as the CO2 level approaches 5% you will get more carbon pickup. Did you ever play with a range between 2 to 5%? I know this is primarily spray but have you tried these gas blends with short-circuit? Also did you ever try running it on straight mild steel?
#33 ·
@ weld - Had a chemical plant that liked “Core Bright” from alloy rods on their stuff – so whatever esab has that looks the same (I'd call them). The boys loved it – shiny, good bead shape and pretty much refused to “fingernail” at the toes.
I kinda wish I'd come across that praxair gas-hat manual a long time ago (I think). Beside the obvious thing of promoting 2&3 part mixes for mo' money, I'd have some questions – Like “why in the wide-wide world of sports” would you want a 2 part purge gas that has argon/hydrogen, or nitrogen/hydrogen blends (Pg 15&18) and HydroStar H-2 & 5 for back purging on stainless pipe (Pg 17&18) in the praxair guide??? WTF - I need some help here.
I think it's reasonable to worry about mig because there are more variables to keep track of to get it right, and it's real easy to go wrong.
I looked at some recommendations (WFS-Volts-Travel speed) & quickly crashed with the evolutions lincoln has over the last 25 years in their docs. From the GMAW manual GS-100 in '90 to the first C4.200 GMAW manual in 10/99 there was little change and they used tables from ASM ninth edition 1983. In the latest PDF version of C4.200 (on line) the tri-mix is the ONLY gas listed for short circuit. I'll post a scan of the old timey lincoln short arc tables for gage to 1/8” & general settings GMAW for SS.
So, being dazed and confused, I decided to look at my lincoln's synergic Ar(mix) settings and what IT thinks it should be doing and it's no where NEAR close to tri-mix settings in the docs... What's left is to wonder if they want Ar/o2, or Ar/Co2 & what balance. It's not in the manual, but for steel the tuning is C25 for short arc - and for pulse it likes C10.
I'm pretty sure - that it wants a more active gas than 98Ar/2Co2 but less than old timey C25 settings looking at the volts, and the jump when the WFS goes from 362IPM to 412IPM. If so then I s'pect the C25 that used to show up with 200-300 stainless was used when corrosion was a non factor, like architectural stuff?
Attached the settings for 035” wire using lincoln SS GMAW synergic mode (PM300) in the third column. The forth & fifth column are SS GMAW settings from the 1991-2 Weld & Fab handbook. In the second attachment notice the volt drops when using Ar/o2 -6V & Ar/Co2 -5V in the left panel.
Matt
#35 ·
Matt thanks for sharing your input and experience. ESAB's wire is definitely top-notch. As a matter of fact so are there Stick electrodes if they were priced equally with Lincoln electric I would say they were better.
I never quite understood why you would need a two-part gas purge unless it is for agitation purposes on the rootside. Maybe someone in the community can chime in on this?
The more I read the more indication there is to being able to operate with just argon and CO2 along with a gas mixer. Again thank you for your contribution and I look forward to anything else you might have to add.
#34 ·
I compared the voltage settings for .035" stainless wire on the Power Wave machines, and the voltage for "Argon mix" is 3 - 4V less than the voltage for tri-mix in the short-arc range of wire feed speeds. Sounds pretty similar to your observations.
I don't personally like short-arc on stainless with Argon-CO2 mix that much. The usable wire feed range is limited, especially vertical-up, and the beads look somewhat cold even at the correct settings. I don't have much experience with tri-mix so I can't comment on that.
I usually use 97% Ar/3% CO2, what Airgas calls "Stainmix Gold".
John
