problem is the exhaust manifold has an EGR tube at the rear held on by one bolt. the bolt is really tight and i can only get the tips of an open end wrench on it. however if i cut off a small piece of a flange on the manifold i can then get enough space to get the wrench on properly. the battery is disconnected but i just want to check with you guys before i do this. last resort is cutting the tube off and fighting to get a new one back there behind the engine.
manifold will not be reused btw.
thanks
thanks
