I am building a hydraulic press for a friend who doesn't want to go the Harbor freight route. I put together a design in SolidWorks along with some modeling to be able to handle 75 tons easily. Even though the design can easily handle 75 tons the actual hydraulic cylinder only needs to generate 20 to 30 tons.
4.5 bore and 3000 psi should produce about 21 tons and a 5 cylinder bore along with 3000 psi should be somewhere around 25 tons.
The design is very similar to K-R-Wilson 75 ton press.
I need help sourcing a reasonably priced hydraulic cylinder that will fit this application(trying to avoid bottle jacks). I thought about utilizing a tie rod cylinder similar to the ones that are sold at Northern tool that fits the parameters above (price tag is around $300). Without going over $500, is there a better option out there for the above application.
Also any good and reliable USA sources for hydraulic cylinders is greatly appreciated.
Any help, comments or knowledge is greatly appreciated. Thank you to everyone in advance who reads this and chooses to respond.
