I have the Harbor Freight welding table. The sheet metal top is bent down at the slots, which helps stiffen the top, but makes clamping a bit more difficult. Because of those bent down edges, using bar clamps or C-clamps means you are reaching under the table to tighten/loosen the clamp.
It would be a lot more convenient to tighten/loosen clamps from above the table. Wondering what guys are using to clamp workpieces down to this and similar tables. DIY'ing a clamp is also an option if there's a good design.
