Fluxcore & rebar?
19K views 20 replies 13 participants last post by  awab
My buddy seen some guys stealing some of his steel to scrap:angry:. While chasing them he rolled his SA250D:angry::realmad:.
He has this lowpay gig welding rebar grids. The mill uses the grids to hold the refractory in the bottom of the latel. He asked me to take it over for him until further notice.
I tried to use Hobart Fabshield 21B .045 flux core, figuring it would go faster. When I started tossing them on the ground, they were breaking apart. It was the weld that was actually breaking. So ended up just using 7018 because thats what he does and never had an issue. These are not rocket science. They are not critical. I was just wondering why the FC didn't work? It was cold out with a really good wind at times. Rebar was ambient temp. I did try to turn up the heat and speed to move faster. Does FC turn sour if you run it hot? But I think some of the ones I welded at normal settings broke also.
#2 ·
I have welded a lot of rebar doing embeds. As long as the rebar says W400 on it, its weldable, otherwise it will give you problems. Hard to say with out seeing the welds. Normally cracking or braking welds means either the weld was improper or the material is hard and needs preheat.
Also are your welds shallow and hot? Sometimes shallow welds crack easily. Post pics if you can.
#4 ·
Yes the welds would be considered heavy spot welds. I am just making a grid and one weld per joint. I will try to grab a pic of one. I already rewelded them with 7018 on the opposite side.
#5 ·
I know rebar is crap metal. And remembering from the past, it is always frowned upon for using it, just like bed frame. But for this purpose, it works. But I can do a search anyway.
#6 ·
rebar isnt crap metal. in a structure it withstands considerable loads. It is not mild steel, and as mentioned, most grades of rebar are not weldable. The rebar I weld onto bent plate to tie into the slab is not the same grade as what the rodbusters put in their dowels. I should learn the specifics; but the stuff I touch is always bundled and marked "weldable".
#7 · (Edited)
Was it weldable rebar? Check for stamped number on the end of the rebar. Will be stamped C60.
Rebar has a very high carbon content and is very susceptible to cracking.
Needs to be preheated to 250Âş then welded with E8018.
For the details to match Weldable type rebar and filler metals see page 17 in the AWS/ANSI D1.4
Yes you can weld rebar with SMAW, GMAW, or FCAW.
There are 3 group classifications of Weldable rebar.
Grade 40,grade 50, and grade 60.
REBAR Grade 40- Filler E7016,E7018,E7028 SMAW. FCAW is E7XT-X (See A5.20)
REBAR Grade 50- Filler E 8015-X,E8018-X,E 8016-X SMAW. FCAW is -XE8XTX
REBAR Grade 60- Filler E9015-X,E9016-X,E9018-X SMAW. FCAW is 9XTX-X
I did not list GMAW filler because you probably will be working outdoors.
Got to have a temp crayon for that preheat.
BTW...Hobart FABSHEILD 21B is a trade name, but is actually E71-T11.
Makes it easy for everyone on the forum to give the AWS number.
So to answer the question directly....We do not know what the rebar type was.
Your Filler metal would have covered C60 in groups 2 and group 3 (ASTM A706) and (ASTM A615,616,and 617), but you did not preheat and so all bets are off.
#8 ·
Only meant crap in the instance that most rebar is difficult to weld and after some thought I remember that I tried doing that last year in school with stick and not liking the results at all. As for its intended purpose for structural reinforcement in cement structures theres no doubt that it is worth its weight in gold.
#10 ·
Turning up the amps using flux core wire can work against you. You will get deeper penetration, but will be mixing more of the high carbon base metal with the fill metal. The resulting weld profile will probably be more concave, and the lighter slag will result in a faxter quench rate. Like Donald said, when you take short cuts and deviate from engineered procedures, all bets are off. A lot of welders who are very qualified will argue that it can or can't be done based on their personal experiences, but the fact that you working under less than ideal conditions also worked against you.
#11 ·
This might be one of those instances where "ignorance is bliss". No one ever told me that rebar wasn't weldable, so I've been happily welding it for over 40 years with both stick and mig. I make my own fireplace gratings out of it too. Maybe I've always been lucky in getting "weldable" rebar?
#15 ·
I will try to get a number off of the rebar mon. I got it pre cut into 9" and 13" pieces in two drums. I will also take a pic of the finished product. I am going to guess it is the cheapest rebar available.
#16 ·
I have done a fair amount of splicing rebar in precast concrete panels. Used a combination of joint details 13-19, and 13-28, always used Lincoln's NS-3M.
#17 ·
I have 6 sets of wps and pull test certs for welding rebar all with E71T-8-H16 class flux core wires
#18 ·
Like I said, this is not critical. Any bad weldor could do this job.
Here is the marking on the rebar.
Here is one completed. They refer to them as "chicken ladders". Four welds....DONE!
Here is the empty jig I whipped up really quick.
Here is the jig loaded up to weld four at a time.
#19 ·
"Chicken ladder jig" :laugh: That'll have folks scracting their heads wondering WTF.
So those things must be disposable then? Just what is it they get used for? Besides chicken ladders that is. ;)
#20 ·
You know, I have used rebar for years on the farm. We actually made a scaling drum out of 3/8 Rb to take scales off of fish. Ive also used it for rungs on ladders that went some 15 feet high ( top of a food pellet hopper). Now that I think of it, Ive welded probably a ton of the stuff....table legs.....tool hangers...cable hangers...weed draggers...My gosh, all the weed draggers. I have always used 6011 1/8th to weld it. Glad no one ever got hurt??!!
JD
#21 ·
