Hi, I inherited my grandpa's century 130 mig, but I can't find the manual. I am fairly new to welding and want to make sure I have it set up right I would appreciate it if you could email me the manual @
lucas@ctmorse.com.
Thank you,
Lucas Morse
See my post above, and my post #33 above. Trust me, there's nothing else in the Century 130 manual that is unique to this welder. Any welder manual will cover safety, input power, bead appearance, etc, same as that manual.
A manual for another 110v mig (or flux) transformer-based welder would be the best match.
Note you need a 110v wall outlet providing 30 amps (nobody has that!) and Century's special input cable with the 130 amp plug (unique to that mythical 30 amp outlet) to get the rated 130 amps output of welding current. Realistic welding power running from from a household 110v outlet is same as any other 110v transformer-based welder, 90 amps or maybe a little more.
It uses generic Tweco tips, widely sold.
I liked mine, but after a few years I got an opportunity to buy a lot more gear for less than the $150 I bought/sold my Century for.
I don't miss the weight of that heavy transformer-based welder. After a couple years using a similar, heavy, 240v welder, last month I bought a modern Amico 130a Flux 'mig' welder that is similar to the Century but only 18 lbs, and dual voltage, so it really can do 130 amps when plugged into a 240 v welder outlet.
Here's a review I wrote about my new Amico.
Review: Amico MIG-130A, 130 Amp Flux Wire Welder, 110/230V Dual Voltage. $149 on Amazon.
