I am working on a copper cowboy hat, full size. I have been struggling with TIG welding it, and decided to try brazing, with silicon bronze rod. (The dome is one piece, I am trying to weld or braze the brim on).
I tried with a number 2 welding/brazing tip on my Victor 100FC torch. I was working a test piece, maybe 6 inches in diameter, so much smaller than the hat. Apparently I am not even close to having enough heat to braze something that large; the copper seems to pull the heat away faster than I can deliver it. If I look at the application chart for the #2 tip, it says it should work on 3/64" to 3/32" thickness, but presumably those numbers are for steel. I am using 32 oz copper, about 0.040" or 1 mm thick. I tried to braze some small pieces with the #2 tip, and that worked fine, no surprise. I tried using my cutting tip, but I think that I got the tip too hot; I could see the flames go in strange directions, probably will need to replace the tip. I tried braze welding with my TIG torch, but had the same problems that I had with TIG welding. Should I try a rosebud? Am I just kidding myself that I can braze such a large piece of copper?
Maybe it did not help that I was clamping the pieces together using a 1/4" steel plate.....
I rarely braze, and when I do I usually braze weld with my TIG torch.
Any comments on off brand vs. Victor welding tips? The price of the off brand on ebay is dramatically less than the Victor tips. The number 2 tip is the largest I have, but I see that larger tips are available. I have a Victor 100FC torch handle.
Comments? Thoughts? Experiences?
Richard
Richard
