I am a student in a community college welding program. I am having problem welding 7018 uphill, the weld drips. I am using a1/8 rod at 120amps on a Miller XMT 350 cc/cv. My welds are fine up to about a 65 degree up angle but when I hit 90 degrees the weld pool drips metal. My travel speed is moderate with no undercut and I use a side to side motion with a slight pause at each side ( not doing a wide weave) and a 15 degree rod up angle in my stinger.
Any suggestions you can offer to correct this problem will be greatly appreciated.
Thank you very much.
