Last night I was welding 304 stainless with mild steel wire + 75% Ar - 25% CO2 and it was going just fine (more or less, minus the black soot and starting). Picked up some Blue Demon stainless wire from amazon and a tank of trimix today (airgas) and the problems started. When I switched to the recommended Trimix + Stainless wire all I got was sputtering and could not put down a nice bead regardless of my settings.
Setup that can't put down a bead:
110v Welder (campbell hausfeld wf2160)
Trimix (90-7.5-2.5 from Airgas)
Blue Demon 308 Stainless Steel Wire. 0.023". *****Just looked around online and am seeing that this stuff is cr*p. Will go to airgas tomorrow and pick up a different spool of stainless wire.*****
0.024" Welding Tip.
Was working more or less "fine" with:
75% Ar 25% CO2 from LWS
Hobart 0.024" Mild Steel Wire
0.024" Welding Tip
Please see the videos below to show what I mean:
Blue Demon 308 0.023" Stainless Wire with Trimix. Welding 304 Stainless Pipe
https://youtu.be/u5I4b3KzZNs
Hobart 0.024" Mild Steel Wire with 75-25 Welding 304 Stainless Pipe ***BEST RESULT***
https://youtu.be/tJdtLn3-w3Q
Thanks for all your help!
0.024" Welding Tip.
0.024" Welding Tip
