I'm familiar with the clamp idea, but don't have any such clamps. What is the joint width required to fit them in? 1/16", maybe .050"? If made with a thicker thru-piece, any reason it couldn't be thinned? Sounds promising.
Hi Oldiron2, thanks for the reply. We're looking at upwards of 560lbm (253kg). Of course not all that weight is supported by magnets in the current plan, but we think there'll still be a decent clamping load required (we're estimating 50lbf from some napkin calcs but not sure). It's also not possible to get C-clamps in there cause there's nowhere for the arm to go around.
I've never worked with this clay stuff. I tried looking it up and couldn't find much. Is it strong? Where can I get some if it is?
Thanks.
It is, I believe, just fine ceramic clay mixed with some kind of oil to make a plastic mass that can be molded into shapes. Used to be sold in boxes with four 'sticks', each a different color, but may have been replaced by modern "safer" crappy products. For something that size and weight, it probably wouldn't be suitable.
If the above sheetmetal clamp idea doesn't suit you, you could use blocks of wood to make multi-angle jigs, fitted to the edges of the metal near the joints, and use contact cement or something similar to adhere the metal to them. It would be strong but would require lots of time and work. Heat would likely be needed to remove them, once done tacking.
If your sections are big enough to
have the magnets far from the edges, if the magnet pairs are strong enough to hold the parts, and if the magnets can be joined together securely enough to maintain multiple section positions accurately enough, I think it would work. Easy to test the idea with some similar pieces of material and same joint type.
How many of these devices are being made? Enough to justify building a multi-arm jig to hold all or most pieces at one time, so fitting the later/last sections in isn't a problem due to distortion or slippage?
Are these devices for use on earth or in space? What quality welds does it need; absolute perfection in all ways, or 'normal strength' only?
