I have a severely stuck MT3 arbor in the quill on my drill press. Trying to eliminate run out I tapped on the chuck and the arbor broke. I tried heating and putting penetrating oil around the tang and giving a drift a good whack but it wouldn't budge. There is a possibility loctite may have been used on the taper. I loaned the drill press to a friend and who knows what he did with it. There is about 3/8" of the arbor sticking out. Being out of options I was thinking of welding some flat bar on the extended arbor that I could hit on if needed but hoping the shock from the heat of welding would loosen the taper enough it would let loose. I now it works good for removing stuck and/or broken off bolts. Do you think this could work and if not is there some other way to get the arbor out?
