Hey Jackson,
There are applications that could be done with a high rpm(5800) saw if you know how to set one up. You did not provide any info. regarding the sizes, grades, or configurations of metal you want to cut. Answers can be supplied if you indicate what you want to cut. For my CS & aluminum stock, I use a P-C 14"dry cut saw(1400rpm). With alum. sheetmetal(<.250"), I use a 10" table saw(5800 rpm) w/C5 tung-tipped non-ferrous Irwin metal cutting blade. You must bear in mind the rpm of a saw & what it is capable of doing. Some wood-cutting saws can be used occasionally for metal, although their design may cause issues with the metal chips getting to the interior & cause failure unless their shielded. Every material has an optimum SFM cutting ratio that lends to easy cutting. With a circular saw, the circumference of the blade & the rpm will determine SFM & generally a lower SFM is utilized for metal. Alum. does like to be cut at higher speeds. I have seen good, heavy duty wood bandsaws converted for metal, although pulley configuration changed to reduce SFM. Anyway, if you explain the parameters of your use & needs, the forum members can provide much better data with more concise equip./accessory descriptions.
Denny
