SA 200 Year?
1 reading
11K views 15 replies 6 participants last post by  Cruizer
I just purchased a SA 200 Lincoln. The code is 9053, when I check it on Lincolns site the best I could come up with was 1987. The serial number is A-1069966, with this I cant find any place that has this number. Does anyone know what year this machine is for sure? By the way it runs and welds great. Purchase price 650.00 on factory lincoln trailer with 200' of lead, pretty good deal I hope. Thanks
#5 ·
The stator coils on that machine would be aluminum. They switched from copper to aluminum in the early 1970s. Lincoln went back to all copper when the Classic I replaced the SA-200.
One way to tell is from the shape of the generator. A main generator frame that is round will have copper coils, one that is octagon shaped will have some aluminum coils.
To the best of my knowledge, the armatures have always been all copper.
Bob
#6 ·
Bob
Thanks for all the input! It is octagon shaped. Can the aluminum ones be changed to copper or should I not worry about them? Will this hold up for pipelining or should I look for an older model with all copper. The welder I help doesn't know alot about these welders he has a classic 300D and before that he had a mid 60"s SA 200. I've been using his to practice with and it does weld easier or slicker then the one I just got. The one I have works good and I can lay in a great bead with it but I will need one I can count on in the feild. I've seen other new welders brake out and have trouble with their machines and it's not a good thing with the job foreman.
#7 ·
There are a lot of aluminum wound SA-200s on pipelines and yours has apparently been working fine for more than 20 years. The design isn't all that prone to breakdowns, but if you're concerned, you should have a good, experienced repair technician carefully check it over. Any machine can break down, even new ones have problems sometimes.
Good luck,
Bob
#8 · (Edited)
Here's a pic from when I picked it up. I have taken all the sheet metal off and sand blasted it and primed it. I also purchased all new plugs, wires, thermastac, hoses (fuel, rad, overflow) got oil pressure & water temp gauge also. I power washed the unit after the sheet metal was off. Cleaned it all up and painted it. As soon as I get the sheet metal all painted I will post some better pic's.
Can't figure out how to upload the pic, can someone help with this. Thanks
#10 · (Edited)
Pic of how it looks after I took it apart, sanded and painted, and replaced all hoses & belts, clamps, added temp & oil pressure gauge, clear fuel filter, spark plugs & wires, I also added a brass ball valve with a hose nipple on it to change the oil easy when it's on my truck. I think it turned out pretty good for the first one I did.
#13 ·
:blob1: In 73 and 74 Lincoln tried going with Aluminum SHUNT field coils. The following (I hope) are pics of 3 different generator housings. ALL are constructed the same inside, except the 73 has aluminum shunt field coils.
Illustrated 64 housing:
<br>
73 housing
<br>
52 housing
I hope this helps.
