question on tig welding chromoly tubbing
12K views 24 replies 13 participants last post by  taz00
was told by a chassis builder that he welds all his chromoly roll cage tubing up with stainless rod. now being im new to welding chromoly tubing and searching the ole interweb most use ER70S2 rod. but he said the reason he uses the stainless rod is that it makes the weld less brittle and not want to crack, this is welding 083 and 095 wall tubing.
someone give me a run down on if this is true thanks..
#2 ·
Welding 4130 with 309 or 312 happens on a regular basis in a lot of shops. By the book, er70s-2 (or -6) or er80s-d2 is a more appropriate choice, but fabricators make their own choices unless a specific rod is called out on a print.
To his specific point about crack sensitivity, with proper prep and technique, the mild steel fillers will produce an adequately ductile weld deposit.
#13 ·
ok fixing to build a set of control arms and the ball joint cups I get, I can only get them in mild steel. is this going to be a big problem welding the 1inch 095 wall chrome moly tubbing to the mild steel and not have it break?
also if im welding a say the 1 5/8 083 wall tubbing to say the 1/8 thick mild steel frame what rod would I use? ER80S-D2 or the ER70S-2 or 6?
#15 ·
Stroker, are you sure your capable of producing the quality of welds required on control arms for a dragtruck? The questions you're asking are usually answered in books that most of us have/had.
#17 ·
im new to the tig welding world but have been doing fab work for a long time. I would just use my mig and build them out of mild steel but I want them built out of something lighter and stronger. so to answer your question yes I feel that iam, but I just needed a few details covered before I tackle them. I will do some trial runs before I jump on them so I can get the feel for the tig and post pix for yall..
