I need to weld very thin sheet or foil...about 0.1 mm to 0.3 mm...in stainless T-347...
can this be done with a tig welder...?
Regards,
Gordon.
Regards,
Gordon.
I'm sorry to say this.. but that won't work, you are trying to weld 2 pieces of metal with a rod that is 8-25 times larger, the energy needed to melt the 2,4 wire will be too much for the thin material. Tig welding is not brazing, the welded part must melt too.. maybe you consider brazing as a process....Thanks for the info...
The idea is to join two thin sheets arranged parallel to each other with a gap of about 2.5 mm between them...I was thinking of putting the copper strip in between and then laying a 2.5mm wire in the gap and resting on the copper...and then welding the thing shut...
capabilities of machines are usually overrated by manufacturers ...I was looking at the specs on some Miller machines and some of them claim down to 0.1 mm...these have high speed pulse up to 500 ppm...
Not sure how optimistic that is...
Just wait for a while there are some guys around here that know a lot more about thin material welding then I do.I should add that I have never tried tig and would need to buy equipment in order to do this project...I have owned an oxy-acetylene set for many years and have managed to get good results when need be...but never anything this thin...
Regards,
Gordon.
oh.. 300 meters of weld .. I like that, it's like +50k eurosI'm sure I could get a shop to microtig this for me...but the issue is the cost...there are over 300 pieces to weld up...each one consisting of over 1 meter of weld length...
Gordon.
I wouldn't think it would be hard to form due to how thin the material is. If you can get it in a softer work hardening state (that is called the material's "hardness", and may be available in for example, annealed, quarter-hard, half-hard, full-hard, etc), that would make it more formable. Full hard material would probably not be a good idea. With it quarter-hard or annealed especially, it shouldn't take that much force to get it to move how you want it to.Jakeru...thanks for some good suggestions...
I had considered pinching the edges together and thereby eliminating the need for a filler piece...however I figured that forming the piece in such a way would require special stamping dies which would be expensive...
Yes, that's right; Just melting two pieces together without adding any filler rod. The attached picture shows .012" thick copper sheet being edge welded autogenously using the manual TIG process, as an example. In this example, the sheets were not restrained by clamping as I suggested, but they were tack welded about every inch to keep the sheets from pulling away during welding. The edges need to be kept very close - ideally touching - for this to work.What dows "autogenously" mean...?...is that welding without filler material...?
