Millermatic / Multimatic 255 pulse mig settings - ARC control
1 reading
3.2K views 1 reply 2 participants last post by  Reyn
I had been struggling with the pulse MIG settings on my machine for 1/8 inch material. Anything less than quarter inch really. Using the autoset feature, I couldn't seem to stop the occasional to frequent short circuit crackling regardless of how I set the arc length. But I finally cracked the code. I find that if I turn off the autoset feature, the same wire speed and arc length recommendations work much better if I increase the arc control setting. I am guessing there is something in the autoset logic that either needs to be corrected, or most likely just doesn't work with the way I use the machine. The default setting for arc control (this used to be called arc sharp I believe, in the millermatic 350P) is 25. If I increase it to 35-40 I get a perfect sound pulse MIG buzz (hum?) without any short circuiting or any spatter whatsoever. I also find that turning up the arc control makes the arc much more tolerant to manipulation. I can now do small lower case 'e' loops without inducing any spatter. I find that doing some manipulation helps me to better gauge my travel speed and produce a more uniform bead, despite the fact that some experts say you shouldn't manipulate the gun when pulse welding. I will have to do some cut and etch samples soon to see if it matters.
I thought I would put this up here for other new multimatic/millermatic 255 owners.
#2 ·
Got me some C10 finally and the arc control at 40 was 100 percent better than the 25 on autoset. I was getting the 50 on the left side confused with it until i saw some of your post on going to set up. I stayed on manual mode and kicked it down to 25 and it was the same as it was on autoset, spatter and all which shows that's the issue. On 40 it hummed in there perfectly. This was 3/16. I haven't tried any other setting beside 40 yet. I'm betting this is why that video Baker's gas did on the pulse was acting like short circuit. They were probably on auto set pulse.
