Millermatic 200 fan on demand help
1 reading
3.3K views 4 replies 3 participants last post by  walker
S/n jg041304
Stock 048291
Typically when unit gets warm, the fan will run till cooled off.
Now, it runs off on off on off on off on in spurts until cool.
Help?.
#2 ·
Could be a failing TP1 (in transformer) or TB2 (on output rectifier).
#4 ·
Sure. Locate wire #1 at fuse F1 holder and run from there directly to fan motor wire #20. This will by-pass both TP1 and TP2 causing the fan to run continuously when the machine is powered up.
If it still cuts in and out with TP1 and TP2 by-passed then I'd check the fuse/fuse holder and fan motor for issues.
