OUCH! That reminds me of a motor base adapter I designed & tacked it together, I sent it to the Boiler Shop where a little guy that worked full time welding new ends on punch pars for the copper smelter, He' throw down 1/8th 7018 @ 180 amps, needless to say when I got my adapter back the 1/2" motor base warped so bad that I couldn't mill it flat, I cut it off & welded a plate back on myself, the only reason I sent it over was because I really didn't want to drag my welding stuff out. I finally got ahold of a motor and figured out how to put a proper bearing in the end. The motors only had one bearing on the fan end and depended on the spline coupling on the drive end for support from the gearbox bearings, they just didn't hold up. Everything was there in the end bell for a bearing so all I had to do was make a short sleeve to fit the od of the shaft and the id of the proper bearing, easy peasy and after setup I could machine a piece of tubing to size plus a few Thousandths on the od and give it a light skim to size after on the motor shaft and do 6 or 8 motors an hour including teardown machine & press work and reassembly. They were designed to fail.
