Lincoln 275 Square Wave too big?
8.7K views 18 replies 9 participants last post by  outlaw105fan
I am starting up a small light fab shop and am looking to get a tig welder for aluminum products. Nothing extravagant just some basic stuff, i.e. turbo systems, exhaust, etc.
I found a Lincoln Square Wave 275 at a steal of a price but it may be too big for my purposes, literally in many ways. I have nee tossing TA 186 and HTP 221 but this one is way cheaper and is pretty capable. Many tradeoffs - do the inverter benefits outweigh the 275? is the 275 just tooo big? is there such a thing?
I have my own answer but wanted to see if anyone had perspectives I had not considered.
Thanks
#3 ·
Too big for aluminum? Hell no :D
Just feed it a lot of power and you're all set :waving:
How many amps do you have available to feed it?
#5 ·
50 amps is not very much for a big transformer based machine.
I run my Airco on 60 amps and it'll tig up to 230 amps AC just fine - not sure what the square wave would do.
I have not tested my Airco to see how far it'll run on the 60 amp circuit, but I'd bet it's not much higher than what I've run so far.
#6 ·
I believe that SW 275 goes up to 340amps.
Your gonna want a 100amp breaker for it.
#9 ·
If you want portability, then your decision is made for you.
#12 ·
315 amps is kind of hard to argue with when welding aluminum. That's a 50% increase in output over any of the inverters you mentioned. Yes, you won't have frequency control, but I am not sure that frequency control can make up for a 100 amp power difference.
#13 ·
I think people get to hung up the whole "portability" of welders. a big welder will roll around a shop just as good as any inverter.
