Lets see, needs power pcb and both IGBT. Must have a burnt part just above the right IGBT and if you check the transistor on the heat sink above that, at the top of the pcb, you should find it shorted. seen a few with this problem. fixed when in warranty and whole machine got replaced when out. worked with Hypertherm rep on a trade in.
the right hand(PFC) IGBT is not just an IGBT there is more to it. The left one (inverter) IGBT is a standard IGBT block of two. Good luck finding anybody who will attempt to fix this power pcb, If not repaired right the IGBTs could fail again and damage the pcb and more.
