I got tired of unplug/plug the air hose for the different uses. I checked for air manifolds, but nothing was to my liking and if, it was too expensive.
I used 4" black pipe pieces and 3/8" T's. I connected the 1/4" air coupler with a 3/8" to 1/4" connector. First I wanted to use copper, but I wasn't sure how to best connect the pipe to the wall.
I have read the discussion about possible rust using black pipe, but my air is very dry so this wasn't a problem for me.
The right most coupler is for the plasma cutter. I can switch off the air flow and discharge the hose with the smaller valve.
The left side coupler is connected to a low-CFM valve. The manifold is pressured with about 100 PSI preset at the compressor and can be relieved using the left most valve (below the pressure gauge).
The frame is screwed with four screws to the studs:
Frame without the manifold:
What would be a project without a mishap. In all the excitment, I added the tray to the lower side of the frame first
