Was wondering if anyone knows how this rod end comes off. It appears it is threaded and the rod needs to be removed. Suppose to be a JD, 8223-C is stamped on the the rod end but I cannot find anything about it. Just thought I would ask, thanks
REPLY: ok thanks. As mentioned above I will check again for set screw. This is on a tractor front end loader, obviously an old one. The original cylinders wore out and PO had these JD cylinders as spare. The rod eyes would not fit into the factory connections (1 1/2" wide) so they welded (not very well) a couple of straps on each side to accommodate the JD rod eyes. So either the rod eyes need to be machined to fit original factory connection points or new eyes installed. Thanks for your suggestion, I will take one off and see if a little heat and a strap will do the trick. Appreciate both repliesCan't answer for that exact application but I've seen similar where they are threaded into the "T" joint. It will take a bench vise and heat to get it apart but once it breaks free, will spin out easily. Use a strap wrench on the other end of the cylinder rod with the "T" anchored into a bench vise and heat it dull red. Then apply torque to the other end of the rod until it spins out. As mentioned, look for set screws but I don't think I've ever seen one myself, (which means nothing).
geezer
Hydraulic Tee's don't have set screws - sets are not up to the task,
nor - is it cast on chrome?
Opus
why do you need to take the "T" end off?Was wondering if anyone knows how this rod end comes off. It appears it is threaded and the rod needs to be removed. Suppose to be a JD, 8223-C is stamped on the the rod end but I cannot find anything about it. Just thought I would ask, thanks View attachment 1171141
From looking at the rod that's exposed I do wonder about the condition of the rest. The truth is the price that was quoted earlier is cheap. Just a seal kit from John Deere runs over $100 normally.Yep, if you take those into a shop that works on them a lot, I think they would just dismantle the tie rods on the cylinders and leave your "t"'s alone. If they are just too wide to fit in the original location, I'd spend some quality time on the sides with a grinder, but be aware that other clearance issues may show up if that "t" is closer to the top of the cylinder than the original ones were. The bigger issue is going to be the condition of the chromed rods... any pitting, rust, gouges or bends is pretty much going to send you shopping for new cylinders anyway. If you do go shopping for brand X cylinders, pay very close attention to the original specs for the application... ie, extended length, contracted length, port locations, port sizes, pin sizes, etc. Just finding 2 18" cylinders can leave you with some wide variations that will not work in all circumstances.
REPLY: So I remove the bolt (which should be a pin) holding the tie rod end in place and the tie rod end pulls off?No problem. There's a lot of different ways that cylinders are put together. Sometimes it's not obvious how to get them apart, other times it's just down right difficult to do. But tie rod cylinders are by far the easiest to get apart.
