I noticed you can by powder coating spray guns etc. Anyone here use one? and is it worth it?
---------------------------------------------------------gnm109 said:This is an interesting topic.
I'm in the process of building my own powder coating oven. It is about 75% done. Frame is 2"X2"X2" 20 ga. galv. sheet metal channel, MIG welded together. The sides will be covered with 22 ga. sheet metal snap-riveted on with rock wool oven insulation in the middle. Inside dimensions are 72" deep, 36" high and 24" wide. This is designed as a dual purpose oven for both powdercoating motorcycle frames and other parts as well as some pre-heating and heat-treating for welding. It's capable of up to 500 degrees F. I have been powdercoating small parts with a toaster oven for some time and we typically will use 450 deg. F. for a half hour. Results are quite good using an inexpensive gun presently, although we will be upgrading when the big oven is finished.
I'm going to be using 4 2,500 watt oven elements. These are controlled by a 110/220 relay (definite purpose contactor) and an oven thermostat. We have 4 conductor 6 ga wire to the machine so I anticipate it will be OK. (Please, please don't start a discussion telilng me that i will need 4 "0" gage conductors Hahahahaha.)
I'll try getting some pictures on here soon when I figure out how to do it. Ha.
For some great insight to how to do this yourself, the link below shows how one fellow handled the problem. He used foam insulation which would be very good except for the cost in my area. He also makes great use of his sheet metal tools - and skills which are really very expert. This website has been an inspiration to me and the fellow who operates it is more than willing to help others who are interested. His website is the only one I've found on the internet that shows how to do it. In particular his wiring diagrams, material lists and general philosphy on the topic. By the way, he does not feel that a blower is of any use in this size cabinet and he's been doing powdercoating for some time without one.
The nice thing about this project for me is that it's motorcycle-related. That's how I got started welding. Also it makes use of other tools you may have (or want to convince your spouse that you need!) such as lathe, milling machine or mill drill, MIG, TIG and arc, not to mention OA cutting and brazing, all of which I have used so far on this project.
GNM109
http://powdercoatoven.4t.com/
