Ok, here we go again,...
I'll set the stage first.
O/A outfit lives outside in PA winter. Regulators are exposed to freezing rain with no protection. 100' hoses. Flashback arresters on output of regulators before hose. No. 2 Victor cutting tip.
Torch operater,(NOT ME!) is burning bolt holes in top of I beam to accept housing that is sitting on the beam. The housing is 3/8" plate and there is a shim of 1/2" plate under it,both with holes punched already, so he has a hole of almost one inch deep that he is stuffing that tip into to cut the matching hole in the beam.
I'm doing other things and look up to see torch operater with torch spewing black soot in the same way that a properly adjusted torch burns a flame. Being a safety conscious fella, of course, I calmly reach over to the acetylene tank and close the valve as quickly as I can, then close the Oxy. tank. In the mean time he had closed the valves on the torch, but when he opened them again he still had black soot shooting out of the torch full force. With the tanks both shut off, I felt slightly safer, and figured that if there was a fire in the hose we should disconnect it from the regs, so that is what I did. Some soot emerged from the fitting when I unhooked the acetylene hose from the reg, but no fire or flames.
The regulators and flashback arresters were taken inside and de-thawed with copious amounts of water emerging from the acetylene reg especially, and the torch tip was thoroughly cleaned.
Given the deep holes that he was trying to start a piercing cut inside, I'm sure he was backfiring the torch.
I reinstalled everything after water mitigation, and used the setup with no problems for an hour or two for other things.
What happened? Was there a fire in the hose? Did the flashback arresters save my ***?
Why does the torch always work fine for me, without making me sh*t my pants?
This guy also has a torch "cleaning technique" that involves purposly backfiring the torch on a piece of wood taught to him by an old ****.
Being of Italian descent myself, I hope none of my uncles used this trick. I never have.
Sorry, had to vent a wee bit.
