I need to get some f-clamps, or all-metal clamps for welding. I won't do anything larger than about 2" square and maybe 8 feet long at the most. Will these work? I'd like something smaller; the ones at HF are huge. I've used small C-clamps that were the right size, but it got tiresome to unscrew them all the time.
Here's what I'm thinking ($16 at weldingoutfitter.com):
Strong Hand Utility Welding Clamps set up 10X faster than C-Clamps.
These welding clamps let you weld in many positions and makes sure the metal stays in place.
Clamp Size: 4 1/2"
Clamping Pressure: 500 LBS
Throat Depth: 3-1/4"
Rail Size: 5/8 x 5/16"
Tapped Hole: 5/16-18 (M8)
Standard Pads
Is this a reputable vendor? How many should I get? I was thinking 2 for now.
Thoughts and comments appreciated! Thanks!
Clamp Size: 4 1/2"
Standard Pads
