Here's my next project: a do it yourself 350 amp capable TIG water cooler made out of a commercial NSS wet vacuum carpet cleaner. I have a Lincoln Square Wave 355 TIG welder and I need a torch water cooler for it and this should fit the bill.
I picked this vacuum extractor at a garage sale last year for free. It has two vacuum pumps, but one is bad. It holds 8 gallons of water and has a working 100 PSI water pump. It's going to require some modifications, but the 120v power supply, control switches, pump, and most hoses are already there. I'll just remove the water heater and the two vacuum pumps and install a fan cooled radiator along with the necessary fittings and hoses. Not sure what type of cooling radiator I'll use, but leaning towards a good PC gaming computer type radiator and fans. The case is a little big, but I have the room in my work shop. It will look right at home sitting next to my huge 550 lb. Lincoln transformer type TIG welder. Any ideas or recommendations are greatly appreciated.
