Advice Fume Extractor
6.5K views 16 replies 7 participants last post by  davec
I want to get a fume extractor for my garage. Space is a premium my LWS sells The Miller FILTAIR 130. Any one use one. The garage door open and fan at the other end is not getting it done, plus its cold as hell.
#5 ·
The 130 Filtair worked fine. I would prefer a bigger fixed unit with a large overhead swinging extraction tube though. Being “portable” just means it takes up more room.
You could most likely wall mount the unit if your welding bench is always in the same area though.
I purchased it new “out of box” off eBay several years ago for a really good price so I certainly didn’t lose money on the deal.
#10 ·
How about using a standard shop vac with a HEPA filter installed? The fumes we don't like to breathe are basically the visible particulates (what causes the smoke to be seen by the naked eye) and certain to be captured by a standard vacuum with a good filter. You could even build a box to hold a second filter inline somewhere if you wanted more protection.
I visited a shop last year that had a very "simple" solution that amounted to nothing more than a 6" flexible duct that ran from the work table to the wall where there was a standard exhaust fan built in. He'd wired an on/off switch right at the bench so it was easy to turn the fan on when you were positioning things. No filtration needed since the fan got the smoke up and out of the building rather than exhausting into the building.
#11 ·
Shop vac would not be the right kind of fan for this. They are high suction but low volume. You want to move a higher volume of air but not with a lot of suction power for this. It is more like ventilation than vacuuming stuff. A furnace fan/squirrel cage would be more the type. Just find or buy one of those and add a filter as desired, but be careful the filter is not going to catch a spark and smolder.
#17 ·
In addition to the ventilation - It is still worth wearing a respirator under your hood, especially for the messier processes like MIG and stick. I always felt queasy after MIG welding a bit in my garage until I started doing that. TIG I don't do it, even though I know I probably should, especially on SS.
