License plates
1 reading
6.3K views 3 replies 3 participants last post by  bkjells
I have never welded anything in my life, but want to learn how to weld license plates together for a project. Should I use a torch or a MIG (TIG too expensive)? Or is there a better option? I'm leaning towards MIG with high volt since they are very thin gauge and aluminum.
#2 ·
Is this the only time you're going to be welding? Mig with aluminum that thin might be a problem. And a Tig machine is expensive.
There are 3m structural adhesives that would to the trick for a lot less money than buying a welder. Properly applied, the aluminum will tear before the adhesive bond fails.
Can you describe the kind of use (or specific stresses) the joined plates will be subjected to?
#3 ·
What are license plates made of, aluminum? TIG may still be an option if you rent one. I would think MIG would handle it fine as long as you not using flux.
