any feedback on ESAB Caddy MIG C160i
17K views 26 replies 10 participants last post by  soutthpaw
just wondering if anyone has experience with this machine
thanks
#3 ·
I dont have that welder,but, I have the big sister to that one, the cadi mig 200. What I can tell you about that machine is that it runs very nice. I have run aluminum with it running the same liner as regular solid without a problem. If the 160 runs the same I would find it to be a nice machine, but you have to run it to be able to determine if you like it. The LWS in my area had a demo unit I was able to try that is what helped me make a decision. Good luck on make your making a decision.
#4 ·
If you can find an ESAB dealer near you, ask them if you can demo one. or ask if they can contact their ESAB rep and get a demo in for you to try out. I have found that ESAB are really good as far as getting their machines out there for folks to try out. I have had 3 different ESAB machines including 2 in my current collection and they are weld/ cut excellent.
#5 · (Edited)
James,
I'll let you know in a week or two, I've got one coming in the mail :)
on a side note though, my LWS didn't recommend them, as they are "all plastic" and apperently one customer dropped his and the inner panel that holds the wire spool broke.
Ron,
what al wire did you run through your 200? I wanted that machine as Esab said it was al capable, and they used to have a teflon liner for it, but now I don't see the liner listed anywhere.
#6 ·
I purchased a ESAB Caddy MIG C200i Welder last summer and used it for about 3 weeks before the little caddy burned up, Esab was very good about the warranty and offered me a new one or my money back I opted for my money back they even paid return shipping with no hassle! I,ll list my pros and cons .
Pro
Inverter,light weight 26 lbs,quick disconnect for gas ,small size,nice smooth arc~ mig weld
Cons
will not take 4' spools of wire as 2' spool axle is molded into inside of case so you have to use 8" spools,
I found that the Q set is awkward ~ maual settings are fine.
no mig gun quick disconnect and only 10 ft gun comes with machine.
Cannot use .045 cored wire,polarity changes are a pain unless you have tiny fingers ,will not take spool gun,
wire drive is all plastic.
Regards
Bob
#7 ·
I use to see the rep out here from time to time and asked him and he said the 5356 is the one to use, and I did use it with out problem. It took a little while to get the tension correct and once it was set it ran fine with out changing the liner. I have since gone back to solid with out a problem as well.
#8 · (Edited)
The 200 is a excellent machine. It is surprisingly good with a liner change, and solid.035 wire. I have the aluminum drive rolls,Nylon liner. I was not impressed with the aluminum welding at all. Short tacks, and it will get you by. If you need aluminum, buy a Passport. If you want to weld SS/Mild Steel then buy a Esab. The gun is a non issue as far as coming off the machine, because it has a excellent cable wrap. Liner changes are easy, and .023 wire welds way better then any passport I have used. The more you use the machine the better you will like it. Can't say that for most machines I have used/owned. The machine really does not like any wire bigger then .035 in size. Not sure if cored wire in .045 would work anyway. The q-set can get you kind of close using .030 solid wire, but since it's easy enough to dial in without it, better just not using it. It runs on a generator super because of PFC, and just might be the best little mig machine off a smaller generator. Works very well off my 4k Thermal-arc 170 Scout. I really like the non adjustable spool adjustment, makes wire changes very fast, and always right on. Can't run the small spools, but you gain in ease of use. I paid $850 new, and it turned out to be a great deal. I have a feeling the C-160 will be a nice unit if you .use .035 wire to gain a bit more on top. Less wfs with that unit, about the same as the new Passport. One note on the wire drive. non issue on the the plastic, and the M\motor is much more powerful then the small Miller or Hobart wire drives. Feed the wire in the machine very easy, and it just works great.
#12 ·
From the ad...
These are new units with full factory warranties.
We purchased these welders at a great price from the factory and we are passing
the savings to our customers.
Get yours today to this extremely low price.
#14 ·
Mine will be here Thursday. Since they had the 300 on sale too, i guess that one is going by-by... I heard it was due for a upgrade, when my friend went back there, a year or two ago. About all they build that is USA as far as welding machines. Maybe a 3500 inverter too. Going to suck if they screw with that one much. For $469.00, go ahead and upgrade the price too. :D The Thermal 161s I bought at a real good discount is still being sold at the higher price, so machine makers don't always kill machines that have been discounted. I really like the 200, and if the 160 is half as good, then I will be real happy. Bought the 200 for $850.00, so half as good is about right.:D i kind of have a feeling it better then half as good. Going to suck if it's better. Probably hard to make much better in arc quality.
#16 ·
LOL! GUESS WHAT WAS ON MY FRONT PORCH TODAY!!!
I only had time to set it up and play for a couple minutes, and here's my thoughts on that:
1. money well spent for a new unit. I've had Migatronics (don't remember the model, but it was dual voltage and my absolute fav), Lincoln 155 tapped, Lincoln 125 continuous, and the Thermal Arc 180 Fabricator. I don't generally buy anything new, and the Migatronics and the Caddy are the only ones, but the TA didn't even have one roll of wire through it. From what I've done in the 5 mins I could, the Caddy will be my 2nd favorite. I feel the Fabricator was a better welder, but it was tapped voltage/heat output, and dambed heavy as a transformer unit, so limited in that respect.
2. Absolutely a joy to carry around! This is the reason the Caddy wins over the TA Fabricator in my opinion and for my purpose.
3. A little Euro-trashish. No offense to over-seas readers, hell, I drive a Land Rover, but the manual is super vague and in metrics only. And I'm no mathemagician to do conversions. Along with that, it's "semi-automatic" which I assumes mean set plate thickness and pull trigger. I don't like the fact that the heat and wire speed numbers aren't listed on the dials. But there is a heat intensity dial (or something like that) to where you can dial up or down the heat.
Yea, I'm gonna like this little guy, but as X knows, I REALLY wanted a 200 Caddy....but for that ebay price, you can't go wrong. Oh yea, there's alot of plastic. I'm not talking about the drive mechanism, but the case itself. I can kinda believe what my LSW dude said about his customer breaking the inner panel that holds the spool, so don't drop it for God's sake.
#18 · (Edited)
I believe you are going to have to use it with different wire, and combo's before you really see what it's capable of. I don't think you should drop any welder, plastic or metal. :D Took me a while to really like my 200 machine. Huge issue was shortening the nozzle for more stick out. I will compare the two side by side, when mine shows up in a few days. The spool cover is not that hard to change out, probably faster then changing out the gun. I would be more careful of the whip then anything. I think the voltage point is moot, only because less or more is all that is really needed. (for me anyway)
Did yours come with wire, and was the package opened? My 200 came with 10 pounds of Alstate .030 wire. (Spool-arc 86 as far as I can tell) I notice the shipping was 36 pounds, so I have a feeling something is up there. :confused: Looks like 11 lbs info from the Esab web-site..
Ready to Weld package includes: 10 ft. (3 m) MXL 180 torch, R-33 FM580 reg. flowmeter, 10 ft. (3 m) mains cable with 6-50P plug. 15 ft. (4.5m) gas hose with hose clamp and quick connector, return cable with clamp, simple shoulder strap, fitted wear parts in torch/feeder (for .030 in. wire) and instruction manual. We also include 11 lbs. of ESAB’s E70S-6 mild steel .030 in. wire so you can begin welding immediately.
http://www.esabna.com/literature/Ar...rature/Arc Equipment/Welding Packages/C160I_UW_0440 000 031 US FR SA_110615.pdf
http://www.google.com/url?sa=t&rct=...Oe2wWM_8HaCQ&usg=AFQjCNHoFlbIWSBpCYpA6VUS6XLLkP1f3w&sig2=lkKkwpYtvLEmd-P93mPrIg
#17 · (Edited)
I would think u can download a USA version manual from the ESABNA.com website. Lightweight is awesome esp when u figure in the weight of a spool of wire.
I would get a multimeter and a helper and make/record your own voltages and mark those positions on the dial/unit. Can do the same for wire speed. Run it for 15 sec, measure wire and x4 u get the IPM. I did this on my MIGMASTER 250.
#19 ·
X,
they opened the box before shipping to insert the reg (it usually comes seperate) but alas, no wire....
SPaw,
the only thing I could think of when reading your post is "why the hell would a dog look like a lion?!!" Is that some kinda photomagicery stuff?
#20 · (Edited)
X,
Time to E-Mail Esab, and see if the 100 day 100% satisfaction guarantee is valid. Doubt you would get anywhere with the place you bought it from. My wire came in the outside box with the reg.
http://www.esabna.com/support/satisfaction-guarantee.cfm
ebay ad...
New: A brand-new, unused, unopened, undamaged item in its original packaging (where packaging is applicable). Packaging should be the same as what is found in a retail store, unless the item is handmade or was packaged by the manufacturer in non-retail packaging, such as an unprinted box or plastic bag. See the seller's listing for full details. See all condition definitions
#22 ·
SPaw,
ok, I've gotten over your tiger-dog pic and think I can address your statement.
The thing is, the "big" knob adjusts both the heat and the wire speed, while the "little" knob is like a fine tuning for the heat. I don't really like that, but with time I'll learn the ropes. But if you don't mind, tell me how I can test for voltage output, thanks.
BTW, didn't you used to have a different avatar up? Didn't you help me out with a Powcon I used to have?
X,
I probably should push the issue with Esab, but maybe I'll start with the seller to just see what they say.
#23 ·
Ok I didn't know that is how they did the controls. That's pretty weird... though seems like the guys that have them do like them. for voltage just connect one lead of the multimeter to each of the welding leads.
Yep still have the Powcon. its my main machine along with the ESAB Suitcase feeder and the spoolgun
#25 · (Edited)
